HAL.PBB.AddSVLANPSIFail
Description
The message indicates the failure in adding a Customer VLAN to the floodin group of the VLAN or the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library or the low on memory in the system.
Remedy
Retry the configuration so that the ports are re-added or re-deleted to/from the flooding group of I-SID or VLAN.
Severity
Debug-Summary
Message Text
Failed to add CNP ports in I-SID %isidName% to VLAN %vlanName% when %info%.
Message Parameters
Name Type
isidName String
vlanName String
info String
Applicable Platforms
